Hey,
I’m having a bug with the Syncing and Beat Matching with DJ Pro AI Version 3.1.13.
In previous versions, the Sync button would change the speed of the track that it’s selected on.
I.e. if I have a track playing at 128 and another loading at 125, I can choose which speed I want to continue with by choosing which track to sync. If I sync the faster track it will slow down to 125, but if I sync on the other side it speeds up to 128.
On this new version I’m finding this function is different, and it makes it harder to build the set I want.
I’m finding at times that when I click a slower track, it will slow the other track down to match it.
I’ve found a work around, which is that when I change my preferences to Sync Type BMP only, the sync works as it used to (changing the speed of the track that I select).
Problem being, that I quite like the Sync BMP and Beats function!! So during my set I’m going in an out of preferences to toggle between these Sync Types, to sync the track I want, and then reset to beat matching as well.
Are you following!!?? haha
Look, as far as I can tell this is just a bug - I can’t imagine why you’d remove the ability to choose which track changes speed.
If there’s anything you can do to help I’d be very appreciative!!
Cheers, BB
