Bug Report Crossfader is now on the right Filter/Bass Button??
Hello, my Bluetooth Hercules Djay Controller is not working the way it should. I tried everything but nothing changes. The Crossfader is not working anymore, the Fade function is now on the Filter/Bass section and i dont know how to reset or fix it!?
When i connect it with Midi Bluetooth its connecting, but not like before and i dont know why this has happened. Is there an option to send it to back to the manufacture and get a new one? Need Help pleeeease! :frowning:
  1. What device are you currently using? - Samsung Tab S7
  2. Which OS version is running on your device? - One UI Version 5.1 / Android 13
  3. Which djay version are you using? - Version 3.1.2 (50966)
  4. Are you using any controller with djay? - The white Hercules Djay Bluetooth Controller
  5. Please describe - step-by-step - how we can reproduce this issue. I dont know…
