Bug with audio routing ? (when trying to set it in external mixer)
As currently Algoriddim djay does not support native external mixer routing support, I ended up trying the workaround which typically consists of the following settings on software which only supports internal mixer routing mode :
  • Crossfader all the way to the left deck (Deck A),
  • PFL activated on the deck on the right (Deck B),
  • Master routing on channels 1-2,
  • Pre-listen routing on channel 3-4,
  • Master & cue à volume at 100%
It works on every single software but on Algoriddim, I don’t get sound from Deck A for some reason.
Did I miss something ? What is different on djay compared to WeDJ, Cross, DJ Player when set in internal mixer mode or other iOS apps ?
The mixer I tried it on was the Pioneer. DJM S11.
Hi @jayneural,
External mixer mode has been added in the latest version of djay Pro AI for iOS (version 3.6.4). This will allow for routing decks, sampler, or looper to the individual channels of hardware mixers. As this should fix the issue you’ve described here, we’ll close this bug thread for now.
Thanks for your patience, and happy mixing. :headphones:
Hi ! Saw that ! That’s amazing ! Will try to map my DJM S11 as its class
compliant.
Now you guess, we’re going to be begging for more deck players and DVS
support :wink:
Many thanks to Algoriddim for listening to the community ! My good old Technics are eagerly waiting now :yum:
compliant.
support :wink:
compliant.
support :wink:
compliant.
support :wink:
compliant.
support :wink:
compliant.
support :wink:
This topic was automatically closed 3 days after the last reply. New replies are no longer allowed.
