When using a rotary on a midi-controller to change the tempo, it makes unnecessary jumps from 0% to +2% or from 0% to -2%. After this “jump” I’m able to change the speed normally by 1 bpm steps.
No matter what settings I use, the problem persist. Normally the user should be able to change the tempo smoothly from 0% to 0,1% and so on.
Pleas dev-team fix that. That’s really annoying. Doesn’t make fun manually matching the speed this way
Midi-Settings I use:
Midi-Action: Tempo
Control-Type: Rotary (01h/7Fh)
Speed: 20%
Some details:
Using DJay Pro 2.0.10 on the latest MacOS Mojave
Midi-Controller: Allen & Heath Zone:K2
Sorry for bumping my own post. But this bug is really annoying.
Last weekend at a live event I was forced to use the “sync” feature to automatically speed-match my songs. Which is a bummer.
No matter if I us a rotary, a fader or a knob … the user isn’t able to match the speed (bpm) by ear because (software sided) the speed is making jumps from 0% to 0,2% or from 118bpm to 118,4bpm.
DJay Pro becomes useless if you like to mix manually. Or if you like to make B2B with other DJs.
