Hi, I think it would be great to be able to turn filter On or Off with a pad on Reloop Beatpad 2. I also play vinyl using Allen&Heath mixer and this is my favorite technique to turn on bass-line on one record and turn it off on another one at the same time, just by pressing two Filter buttons (filter knob is adjusted to desired frequency, resonance is zero). I don’t like to use EQ for this purpose because EQ is tuned to particular frequency that often ‘kills’ too much mid frequencies, for example vocals. With filter you can tune exactly where bass-line sits. I think some of the 8 instant effects pads do almost the same effect so we can easily remove one of them.
