While playing around with the video effects, i also hear the soundeffects that i don’t want to have in the video. It would be nice to Bypass the soundeffects and only hear the original added audiotrack.
You can currently do this using the split audio/video crossfader that can be enabled in the settings. Simply move the audio crossfader to one side where you play the audio, and the video crossfader to the other where you have the video that you want to apply effects to.
Yes, but that will be using both the deck according with your suggestion. How about if it is a music video (e.g. The Princess Tour)? Do I need to play both deck with the same video? so adding the bypass will be a good idea.
