Camelot Wheel cracked for Djay Pro
Hey, sorry if this has already been sorted, but after so much confusion with the Camelot wheel and the circle of fifths, all you need to do is this:
  1. Ensure music is analysed
  2. Turn off the tab (settings, audio analysis, major/minor) You may need to hit reset in sort before hitting sort in key
  3. Draw your Camelot wheel and ensuring C is at 12 o’clock, on the outside of the wheel (the major side) fill in the remainder 11 letters in the order they appear clockwise, finishing with F.
  4. Then turn on the major/minor tab (again you might need to reset first) and you will see additional major and minor keys listed.
  5. Starting with Am in the minor column under C, Em under G and so on.
Hope that makes sense and more importantly sounds good.
I just wish this was made clear in the first place.
Paul x
Ps Let me know if it doesn’t work for you.
