How can I display key in
Camolet format?
Also
Need the traffic light key system same as rekordbox.
Windows 11
5.4
Flx 4
Camolet format?
Also
Windows 11
5.4
Flx 4
Using Mixed In Key write the data to the comments section. Then you can sort by key and bpm in DJay
Hi @DjSasha_DelhiDevils, in the djay Settings>Library>KEY>Format you can select Numerical Key which is close to the format you’re looking for.
