I’m having trouble allowing TT1 & TT2 to connect with independent channels on my American Audio MXR 19. Both TT’s coming out of one channel. Tried using different channel yet no success.
Anyone configure their American Audio MXR mixer with success with Algoriddim?
Haven’t tested that device yet either but generally speaking, yes you do need a mixer with a built in audio interface if you want to use it for pre-cueing. To set it up, please try the following:
open djay > Preferences > Devices
select your Mixer for Main and/or Pre-cueing output
I am trying to do the same thing with my american audio 19 MXR.
Using the MIDI map in djay, I am able to set “Turntable 1” and “Turntable 2” commands for the MIDI Log 1 channel fader and MIDI Log 2 channel fader of the mixer.
However, I cannot get the headphone “Precueing” to work through the mixer. With your above comment, are you saying that this is not possible? Unless there is a separate USB sound card?
