Can I get a list of songs played?
In earlier versions of Djay, couldn’t you save a text list of songs played in a set? Where is it in Djay Pro? I look through these topics and I see instructions for finding set history in the Library folder. Isn’t there a simple way to save a list of songs played?
Thank you! I had that panel hidden, searched the topic and found the looking in the library folder solution. I knew it had to be simple but couldn’t see it. Also, didn’t see where to download the manual, which I’m doing now.
It leaves a check mark by all of the songs played. That was always fine for me
The orange clock icon in the left column under your iTunes, Spotify, and video icons is your history, it is very detailed and specific, the best.
Hi … section 5.9.11 in the manual …
http://download.algoriddim.com/manual…
