Can I map my Elite mixer to use 4 deck like the S11
Can I map a 2 channel mixer to work like the S11 and be able to load 4 decks. Eg deck 1 and 3 deck 2 and 4. Do you know if I purchase the Rane 72 can this be done. Like instant doubles and have the Neuromix play the drums and bass on one track and vocals on another. I don’t want to buy a new controller or buy a new mixer. I currently use the Reloop elite mixer and want to know if this can be done.
How did you map this?
Deck 1 and 3 to Channel 1, and Deck 2 and 4 to Channel 2 can be done on the Rane 72. Did fumble about with that setup last spring. Seems to work ok.
No idea if it works with the ELITE, but I see no reason why it wont.
Not tried to set up instant double with neuralmix presets, but it seems doable with a bit of trial and error in the midi menu.
If you have the Reloop elite, you should be able to just test if you can get the results you want.
