Can I use a serato first gen mixer with serato vynil controllers with Djay pro?
I have a rane 57SL mixer and Serato vynil controllers, when you map the mixer manually does that include the turntables using serato vynil
The 57SL is not standard MIDI as other Rane mixers were. In other words it can not be used with any other software than SSL. Not even VDJ can use it.
You MAY be able to get the sound card to work but without the other functions it is kind of redundant.
Hey Camron,
we are not supporting DVS/ Time Code Vinyl.
Which mixer are you planning to use exactly?
serato ttm 57SL
