Would be useful to be able to cue and jog tracks off screen
Not correct answer Lukas E.
A good working solution is here : http://hexler.net/
Create your own GUI-Sync it with IOS Device-start the bridge- MIDI learn in djay Pro-Learn your GUI-Commands - Done
Works very good !
Heiko
Hi Reggie Flores,
thank you for your post. We are sorry to tell you but this is not possible.
thank you for your reply Heiko Schliemann. We can’t guarantee third party applications to communicate with djay Pro, but we are glad other that you made it work.
Thank you for your feedback.
