Unable to use turntable for scratching. I have tried to reload program and adjust the touch sensor level. All to no avail. Any other suggestions.
Hi Roderick,
Which controller do you have? Also, what exactly happens when you move the jogwheels?
Hi Nick,
Did you receive my email?
- Which djay version do you have?
- Did you install the latest firmware update for your controller? http://www.pioneer.eu/uk/support/soft…
- What exactly happens when you move the jogwheels?
- Apart from the jogwheels, is your controller working properly with djay?
Hi I have the same problem on the reloop beatpad on mac the jog wheel won’t do scratch it just pitch bends or jog searches
Dave
same here! Using Pioneer DDJ Ergo-V
