Can’t connect Spotify Premium student account
  • Device model (e.g. 2020 iPad Air 4th Gen): redmi note 13 4g pro
  • Version of operating system (e.g. macOS 14.4.1): android 16
  • Version of djay (e.g. 5.1.2): 5.6.1
  • Hardware/controllers used (e.g. Reloop Mixon 8 Pro): dont use
Hi @Bintang_ghaly, welcome to the Community!
  1. Can you please provide more details about the issue you are experiencing?
  2. Are there any error messages?
  3. Perhaps you can share a short screen recording to clarify exactly what the problem is?
  4. Also, what country are you in?
When I try to connect my Spotify account, a pop-up notification like this always appears. When I try to connect my Spotify account, I always get a pop-up notification like this: It says I can’t access my Spotify account because it’s not premium. Even though my Spotify account is already premium for students, as shown in the video, and I’m in Indonesia.
Thanks for the additional info @Bintang_ghaly. According to the Spotify website, the DJ Integration is not yet supported in your country. I recommend you contact Spotify support for more info.
