Can’t log into Beatport
Is it just me?
Hi @RakanIam,
Thank you for your post!
I can share this is something our development team is actively looking into.
In the meantime, can you share what iOS your device is running as well as the djay version you are using?
I’m hitting this issue on both iOS 16.2 (20C65) as well as on macOS 13.1 (22C65) with djay Pro AI version 4.1.5.
Deleting the folder at this path fixed the problem for me:
~/Library/Containers/com.algoriddim.djay-iphone-free/Data/Library/Application Support/djay Pro AI/Beatport
