My son loves the Mixtrack Pro 3 and wants to use the app Djay Pro using the IPad Air .When I connect the Mixtrack to a powered hub it goes through a non stop flashing light show. This renders the controller non useable. Yet others say it will work. What USB hub should I be using? I have the camera connection kit with the lightning lead but can’t do anything until I sort this issue out.
Your help would be very much appreciated
VW
I have this USB Hub. Work with all Controller
If you buy this Camera Connection Kit from Apple Tagen you also can charge your iPhone while connected to Controller
Wow… Thank you Manfred.I didn’t expect a reply so quickly. I will buy it straight away and tell you how I got on . Thank you.
It works fantastically Manfred. Thank you so much for taking the time to contact me and for helping me out.
