Since NI have seemingly left the s4 hanging is there anyway for you guys to reach out and get what’s need so we can run our s4 Kontroler with DJay
i could not run djay pro with s4 . there is no way to activate midi mode with s4 .
Hey @JMAC361 Thanks for reaching out.
As @Enzo_Spina has pointed out, there is no option for MIDI mode with the TRAKTOR Kontrol S4 MK3. Unfortunately, no mapping can be made.
I apologize for the inconvenience! My only suggestion can be to reach out to Native Instruments’ Support team, and request for MIDI Mode capability with the S4.
I wish I had a better answer for you! Feel free to reach out here in the Community if you have any other questions or suggestions and have a great rest of your day ![]()
Have you tried this:
https://maps.djtechtools.com/mappings/8031
What worked for me is after loading and closing Traktor hold down the ‘shift’ (right hand side) then when you press ‘preview’ the decks should light up. I didn’t get round to remapping but maybe this will help?
Good luck ![]()
Hey @ArfurGee - Welcome to the Community. Thanks for your first post ![]()
I appreciate you sharing this link! This will work for the TRAKTOR Kontrol S4 MK2; however, it is the TRAKTOR Kontrol S4 MK3 that does not have MIDI mode.
So, unfortunately, this will not work (unless @JMAC361 or @Enzo_Spina have an MK1 or MK2, which I believe is not the case.)
Thank you for your support, nonetheless!
Ah yeah ok, I didn’t see any mention of which version of the S4 so my post was in relation to my Mk2 decks.
I recently purchased a Traktor S4 and, being new to DJing, I’ve found that Djay Pro Algoriddim is incredibly user-friendly and accessible for beginners. Unfortunately, I’m disappointed because I can’t connect it to my Traktor S4 controller. Is there any possibility that this issue will be resolved in the future?
Hi @Handren_Othman if you have a MK1 or MK2 Traktor Kontrol S4 it’s possible to switch it to MIDI mode. However this is not possible with the MK3. This is a limitation of the hardware from NI which is beyond our control
Unfortunately mine is mk3, any hope this will be solved in future? Or shall i try to get rid of the controller ![]()
@Handren_Othman this would need to be addressed by Native Instruments with a firmware update I believe. This is beyond our control. You can try contacting NI directly, but it might be better to sell it and purchase a controller that is natively supported by djay Pro. You can find the hardware list for each OS below:
I also have a S4Mk3. Great gear and would be finde to use in Djay pro. But i think NI will not do this.
Yeah i think we need to get a NI for their slackness or get on the job
