Wanted to know if it possible. Can you guys have an option to disable the cross fader. And just use the line fader instead. Am more a house Dj and use more the line fader. Sometime my hand will hit the cross fader an it mess up my mix. I know serato has it on there software. Would be nice. Am using the Reloop mixtour with djay pro for iPad
thank you very much for your feature request. Would be great if other users could upvote your request in order to push the topic.
Cheers.
Also for me would be very great if you could disable crossfader…
