at the moment, I use instant fx with Stems assigned to Vocal and drums,
when I activate “instant fx” on “vocal” and then I activate “instant fx” on “drums”
“instant fx” automatically deactivates on vocals. it cannot activate 2 “instant fx’s” at the same time
I want to be able to activate 2 instant fx’s at the same time.
Is this possible?
Hi @eecy_cee, it is not currently possible to activate 2 Instant FX at the same time on the same Deck. You can, however, combine Instant FX with Manual FX. You could also duplicate the song on Deck 1 over to Deck 2 and apply one Instant FX to Deck 1 and another to Deck 2.
@eecy_cee another option you may want to consider is using 2 Manual FX and setting one to Drums and the other to Vocals via the pop-up menu at the bottom. This will apply the FX only to those STEMs instead of applying the FX to the entire Deck. You can actually use 3 Manual FX at the same time.
thanks for the info Slak_Jaw I’ll give it a try:)
Thank you so much Slak_Jaw it worked better than I expected, Its exactly what I wanted for my mapping. Your amazing
You’re welcome @eecy_cee. Glad that worked for you!
