HI chaps, im really very pleased with the ipad app, have used it to dj at a couple of private parties, working through playlists, live mixing, and scratching (sometimes)
i love the way it saves the cue points…but can it save the levels and gain for each individually set track? ive noticed it doesnt and cant work out why the levels keep resetting to their original state.
Hi Andrew,
You can’t save the EQ levels for a specific song but you can disable “Reset EQ”. This way, the EQ does not get reset when you load a new song.
Tap the “gear” icon and go to Settings -> General.
By the way, which iPad do you have?
ipad 2, thanks for answering so swiftly.
