cannot access all three fx in eq tools page when using wego3
I’ve noticed that you can only access the first fx out of three in the eq page on the iPad when plugged into the wego3. Meaning you can’t use the fx pad or manual page for the 2nd or 3rd effect. I’ve tried accessing it in different ways but no luck. Can you look into this please. It’s good to have the touch option too. Thanks .
Hi Bob,
This is not supported. You can only access FX1 in the tools section, which is why we added the extra UI elements in the bottom row for the WeGO 3.
Okay . That’s a workaround for now :slight_smile:
