I don’t use tidal, never have. I am logged into Beatsource. I can add to ‘beatsource’ playlists, no prob. I also have some ‘djay’ playlists, that I have Beatsource tracks added to. Sometimes, I go to add a Beatsource track to a ‘djay’ playlist, and I get an error:
**Cannot add to playlist ** Tracks from TIDAL cannot be mixed with content from other streaming services.
If I restart djay, it will then work (allow me to add that track) without the error. A few songs later, I get the error again when trying to add any track to that playlist.
There are not any Tidal tracks anywhere…I’ve never used/subscribed to Tidal.
I see another in the forums mention that a playlist track magically switched from one source, to Tidal.
Upon further review, THAT happened here as well. I’ve never used or subscribed to Tidal. A song (Hand Clap) curiously switched from Beatsource (as all my tracks are) to Tidal (the little icon in the playlist changed to the “T”).
So I deleted it from the playlist. Then added the song back from Beatsource. And it SWITCHED to tidal again!
I will try to record the bug when I have a moment.
I am having the same issue. However I am subscribed to Tidal and soundcloud. I have tried logging out of Tidal, but I get the same issue.
When trying to make a djay playlist with soundcloud tracks they load as tidal instead and then when trying to add another soundcloud track i get the error “tracks from tidal cannot be mixed with content from other streaming services.”
I have been getting this error for at least a month now. At least since the whole tidal stems debacle.
just tried creating a djay playlist using only tidal tracks and now i’m getting the same error because tracks are loading as soundcloud tracks and when i try to add more tidal tracks i get the error again.
Hi there I have the same issues. I use different streaming services and tracks from different sources and I see a lot of examples where sources are just randomly changed. Combined with a silly limitations from tidal to not have tracks from other sources, it makes the whole library management useless, if you have any streaming service in use. This bug exists since 3 months now and to me it is not acceptable at all. Eighter you fix it asap or just remove this stupid limitation, but you can’t consider yourself a serious dj software and let it happen for such a long period of time. Really annoying
