Hello
I have the hi-fi subscription. I am already logged out on all my devices. I am able to log into the same apple with Tidal without problem.
What can I do?
Hello
What can I do?
Hi @TxanFlin, please close djay and perform a forced restart of your iOS device:
Sorry. It doesn’t work
Hi @TxanFlin, just following up to see if you read my previous message and if you’re still having Tidal login issues. Thanks!
Hi
I will try this afternoon! Thaks for your fast support.
You’re welcome @TxanFlin
In the Iphone works perfectly. Lets try this afternoon with the ipad.
1- i am not connected with any vpn. Directly to my wifi.
2. Here you can find some pics.
3. Yes I can login both on web and on tidal app. Djay app works on iPhone but not in iPad Pro
Thanks for the screenshots @TxanFlin.
No, I have the normal version.
No Pro
I am logged with the same ID.
In iPhone works fine, not in iPad
That is very strange @TxanFlin. I can’t think of anything else to suggest other than to backup your iPad including your djay Media Library database, delete djay from the iPad then reinstall it.
The djay Media Library can be found in the Files App on your iPad under:
On My iPad>djay>User Data> djay Media Library
I would copy this file to your iCloud, an external drive, or simply to another location on your iPad before uninstalling and reinstalling the djay App.
I have tried everything….
Delete all the cookies….
Delete, reinstalll, ……
It is strange that works on iPhone but not in IPad.
1- version 5.0.3
2- IOSPad 17.2
Thanks for the info @TxanFlin. I’m all out of ideas to try, but I’ll forward this to the engineering team to see if they have any suggestions.
thanks.
I will wait till news from your side.
have a nice day
Solved!!! From app I logged out from djay account and tidal and re logged again
That’s good news. Thanks for letting me know.
