I’m wondering if I’ve set up something wrong with my software. I got the idjlive hardware yesterday, and tested out on both my Macbook and my iPad using the djay app. Here are the problems:
- i want it so that if my crossfader is on the right, the right turntable is playing to the audience. and the left is playing in my headphones. However, no matter whether i turn on invert crossfader, turn up the split output volume all the way to CUE or all the way to MIX, the audience speakers will play everything- left and right turntables- at the same time. I’ve tried pushing on or off the little headphone icon on the software, tried turning the volume up or down on the hardware…nothing will allow me to have consistent pre-cueing in my headphones.
Also, and this is hard to explain without demonstrating but, sometimes the software would invert (so crossfader on left is playing right) and i would have to go back and forth for the audience to begin to hear the track i was cueing.
Lastly, the crossfader isnt “fading”. I have to push it flush all the way to one side in order for it to start playing the track. there’s no gradual fade out from one and into the other.
