Cannot use Software FX on DJM S7 & S9
Hi
I am new to Djay pro.
Please tell me if you know.
This is my problem
When i try to use software FX of djaypro, sounds turn to mute. And the small screen on the mixer shows me nothing. And then i change software FX to hardware FX mode on my DJM s7 i can hear the sounds again. What is my problem? Please teach me.
Hi @Djzzam, welcome to the Community! When creating new topics, please do not forget to answer the questions in our template with specific details about your setup not just “iPad” or “Latest Version”. This helps all of our community moderators to provide the most effective support to users with the utmost efficiency. Thanks!
Please also capture and share a short video of your issue to clarify. Thanks!
Hello, I have just bought a DJM S9, and I have the same problem. Did you find a way to fix it ?
I am using Djay pro on MacBook Pro M4.
thanks for support
Jerome
Hi @Jerome_Begot, I never received further details from the OP so this issue hasn’t been investigated further. Can you please share the full details about your setup?
Hardware Firmware Version:
Since this sounds repeatable, can you please also capture and share a short screen recording of the issue to help clarify what’s happening? Thanks!
I belive what Djzzam means is using the software fx on the DJM-S7. It’s premade for serato software effects. Maybe if you investigate mapping it’s possible to re-do it and use the buttons there, but somehow I remember I just decided to give up and use pad fx for software effects within djaypro.
on S-11 there’s dedicated software effects buttons which also work not the same way I would expect them to (they do work, just I do not like it), so I unmapped everything and use them as a idfferent hardware effects selection). hope that helps somehow.
Thanks for the input @Akrilovy
Here are the details:
MacBook Pro M4
Tahoe 26.6.2
DJM S9 1.0.9
Djay pro 5.6.8
Thanks for the video and setup details @Jerome_Begot. Can you please also capture a screen recording of this with the Manual FX section visible in djay? Thanks!
Yeah, it’s serato specific effects inside mapping. Same thing on S7, it just doesn’t work. It does on S11 though.
The Manual Fx section is already available in the Video from my understanding
@Akrilovy Thanks for your feedback. Did you find a useful way to use these buttons ? On the DJM S9 you cannot define hardware Fx on these command
No, I only use them as a hardware fx selection on the S7.
Yes, but I cannot see the laptop screen when you are activating the hardware controls. A screen recording or video that shows both the hardware and screen in the same shot would be helpful. Thanks!
Here it is
Perfect! Thank you @Jerome_Begot
