On DJay 2 , it seemed to be working fine, now when opening it prompts you to select Itunes or Spotify after attempting to select a playlist.
(I dont have Spotify and can’t access it anyway)
It wont let me get past the ITUNES selection and all of the songs below are “grayed” out where you cant select them i.e. - cant get into the playlist any longer??
You can access the songs under songs …but not under playlists???
HELP!!! I have a huge librabry of playlists that I can’t access through this app any longer!!!
