Hi - new user here (used for a while years ago). I’m using v5 on my MacBook Pro, but I can’t seem to be able to create a playlist (seems simple?). I’ve managed to import some songs from my external drive (although it will only search if it is Fat32 which hasn’t been fixed since the last time I used it years ago), but when I try to create a playlist using the + button, nothing happens. Am I doing something wrong?
See screen record here:
Hi @Stuart_Cox1, I don’t have access to a macOS device, but I’m pretty sure the process is very similar to iOS.
- Make sure you are in the My Collection music source
- Select the “+” icon near the top left to bring up the add Playlist, Smart Playlist & Playlist Folder options.
