My Reloop Mixon 8 will not recognise my iPad
or MacBook Pro it just boots up then nothing won’t allow me to update firmware this is only the 2nd time I ve tried to use it …first time it worked fine any help would be really appreciated
Hi @Peter_McIntosh, welcome to the Community! When creating new topics, please do not forget to answer the questions in our template with specific details about your setup not just “iPad” or “Latest Version”. This helps all of our community moderators to provide the most effective support to users with the utmost efficiency. Thanks!
Based on your description, it sounds like it could be one of the following:
- Check the USB switch on the back of the Mixon 8 to ensure that it’s position matches which USB socket you are plugged into.
- Now confirm that the switches on the top of the Mixon 8 near the Gain Knobs are set to the same USB source you are plugged into on the back of the unit.
