I’m trying to delete songs that have been added to the Automix Queue and I can’t seem to do so. I can’t right-click them and get any menu to pop up. There’s not command in the top menu that I can find that will do so.
I’m sure someone using Mac will give you the correct answer.
In the windows version. Clicking the right mouse on a track gives the option to delete from the queue.
Left mouse allows you to drag the track to the right play position.
I am using Djay IOS on an IPad and with that you just touch a track and it pops up with the option to Play now, play next or delete. You should also be able to drag the track to any position too. (I plugged a mouse in and that works the same way with a left click).
Edit
I can only see that happening if you were clicking on a playlist and not the queue. Just a thought!
You can remove tracks from the (Manual, Match, and Playlist) Automix Queue by right-clicking on the track you’d like to delete, see the screenshot below.
