Djay 2 app for ipad
As in tips & tricks list I press and hold load button (if it press once i’got list itunes songs) expect to get audiopaste menu but nothing happen. Did I press wrong button, i’v try almost all buttons but no audio paste menu showup. Sorry for bad eng
Hi Semir,
The menu only pops-up if you already have a song in your clipboard. Please try the following:
- go to the recordings list
- tap and hold on a recording and select “Copy”
- now, tap and hold on the load button and you should be able to select “Paste”
THX, this work!!!
