It’s been a few weeks that I cannot load songs from my iCloud or Box within the Djay app. The app looks like it’s importing but nothing happens once the progress indicator is done.
You really won’t get any Algoriddam support anymore. That went a few months ago. No idea where they all are.
I had the same problem I use itunes go trash bend readd your music back to itunes this will help?
