Can't Play certain song from Tidal
I’ve been with Algoridim from almost a year and this never happened.
When I try to load a song that I already played it appears a square that says: The operation couldn’t be completed. (OSStatus error 1954115647.
We are sorry to hear about the issue you are facing.
Could you share the track format which caused the error?
Also in which library did the error occur?
There are a few tracks, I’m playing them from Tidal, but how can I know the format?
