My itunes library does not appear and I’ve tried the usual things of refreshing djay as well as rebuilding my entire library. Are there any steps I can take to fix this?
Cheers
EDIT: There was an update for iTunes a few days ago, is this related?
i get the exact same thing yet i have never moved my library, only have one library and it’s in the default location. i click ok repeatedly and it doesnt see it, try to select the folder thus directing it to music, or the itunes media folder, or the itunes music folder and click ok and it still comes up with the pop up. eventually clicking ok works but can sometimes be 30 ok presses before it accepts it. need a solution quickly as this has been going on too long and i use this program for my disco business!
I get no error messages either. Just tried the djay demo version and the same thing happens - djay doesn’t ask to see any library and won’t refresh because it says there is no music to refresh. My itunes works fine and my 150+ playlists are all there. They seem to be in .itl files. I know djay needs .xml files but it won’t even ask to use them. I have the hardest time with djay which is really frustrating because I like the look of the software and I have NEVER been able to rely on it. PLEASE HELP!!
I constantly get the window popping up asking to press “ok” to open my iTunes library but when I do, it keeps popping up in a constant loop. How do I solve this?
I just purchased pro, I was happy with the prior version and have used it for some parties with great results using Spotify. However, I have custom mixes created in third party applications like Logic or files in .wav that I need to integrate and just throw into iTunes for playlist quick access to mingle with other tracks. Despite restarts and various approaches I’m not even asked for a window to access iTunes at all and it appears blank. HELP!
ok friends i think i found a solution to the problem all you have to do is to quit the djay software click on your iTunes preference tab on advance and mark share iTunes library xml with other application it think it might work for you
