Cant import the Traktor Kontrol S2 mapping, when I follow the guide and get to the step where you are supposed to install the mapping, the install mapping never happens. When I double click the midimapping file djay pro just opens but doesnt install the mapping. Any suggestions on how to fix it ?
I have the same proble, the mapping Doesn’t appear.
same issue. any resolution?
Lukas - I am having the same issue. Was there any resolution to this?
after double clicking the mapping, have you checked if the midi mapping is appearing under MIDI in the menu bar?
Thank you in advance.
Cheers,Lukas E.
