catalina search box
with catalina desapeared search box!!! What I have to do? thanks
Yes, thanks it works!
Hi Monica,
We are sorry to hear that.
Can you please contact us right away via support@algoriddim.com and attach a link to this thread?
Thank you in advance.
Cheers
same problem
I have the same problem. No search bar is showing.
I answer myself. I found a walkaround for this trouble. If you press cmd+f and continuosly a letter, appears the search bar. And it seems remains till quit the application. As soon you start again the application, the search bar is missing again. Is at the moment a solution. Repeat: Cmd+f and a letter of the keyboard and it appears.
