Hello
I have a Problem i had the CDjs 2000 and it worked perfekt with djay pro 2 now i changed to the cdjs 2000 Nexus 2 and i cant conect it with djay pro. I connect the 2 cdjs with the usb cable push the link button press the enter knob down but there is no deck selection the software seems to reconize the cdjs because there pops up a window if i want to use the cdj 2000 as soundcard but nothing else happens. Sorry for my bad english im a swiss guy
I use the latest version of djay pro. Maybe i need to update the cdjs firmware? The cdjs are new so there ist the manufactur firmware on it.
Please help me fast i have a gig tomorrow.
Thank you
The newly released djay Pro 1.4.3 for Mac is Pioneer DJ certified and comes with native support for the CDJ-2000NXS2 and CDJ-TOUR1 via USB-HID along with DJM-900NXS2 and DJM-TOUR1.
Additionally, using LAN Link (Pro DJ Link) you can connect up to four CDJ-2000NXS2 players with your DJM-900NXS2 mixer via LAN cables, then simply use a single USB cable to connect their Mac to the mixer and everything syncs seamlessly (same for CDJ-TOUR1 players and DJM-TOUR1).
Enjoy!
There is one posted on here http://community.algoriddim.com/algor…
This is NOT working As simple AS that for me, the djay Pro software does NOT see the djm mixer… hey NOT ?
The cdj-2000nxs2 are not yet support natively… You can map it using midi mapping but not sure the result will be perfect.
Thank you for your answer.
Is there any body that has already made a maping for that i can use?
