CDJ 3000 - Jog Wheel Mapping on Djay Pro 2
Hi Guys,
can you please help me with the Jog Wheel Mapping for my CDJ 3000 in Djay Pro 2?
Whatever setting i choose (scratch, jog seek, pitch bend) the software just has very weired outcome - e.g very fast spinning, jumping to the middle of the track, …
I really appriciate your support. If you already have a mapping I would be happy to contribute for your efforts.
Thanks,
Max
PS: I know that the new AI version has native support, but I want to use the Pro 2 version.
Hi @max_meier, try expanding the Advanced Control Configuration section and choosing one of the other Rotary options under Type. You can also adjust the Reaction percentage.
Hi guys,
hello @Slak_Jaw,
after serveral hours, trying every possible combination of scratch settings in advanced mode, I’m still not able to use the jog wheels of the CDJ3000 properly. What is working is when I touch the ring on the side of the platter, but the top of the jog wheel is not working. When I touch the top of the jog wheel it is either doing nothing or spinning like crazy.
Is the Jog Wheel of the CDJ 3000 working at all with DJ Pro 2?
Hi @max_meier, I’m not sure what else to suggest. We stopped supporting djay Pro 2 in June 2022. So perhaps there is a specific CDJ 3000 jogwheel bug in that legacy version of djay. Sorry I couldn’t be of more help. We do have a special loyalty offer for legacy djay users though:
Hey did you fix it? I have same problem for the XDJ-AZ hope we can fix it
5 posts were merged into an existing topic: CDJ-3000 HID Mode Drifting & Unresponsive jogwheel
