In djay pro using a Cdj 3000x to control the software when you press slip mode and then press a loop on screen it stays on. Is there a way to make it a monetary function the same way the Cdj actually operates standalone. It’s well annoying having to double tap it.
Hi @Peter_Lazarenko, thanks for the feedback. I’ve passed this onto the dev team.
Hi @Peter_Lazarenko, engineering has identified the issue and is working on a fix which should be included in an upcoming update (likely 5.6.2). Thanks!
Hello @Peter_Lazarenko, 5.6.2 was released today and should be rolling out to the various apps stores in the next 24-48 hours. Thanks!
Thanks look forward to it ![]()
You’re welcome @Peter_Lazarenko
This is still an issue and didn’t seem to be resolved in any updates. Or is there a specific option needed to be selected now ? Thanks
Hi @Peter_Lazarenko, this should have been fixed with the 5.6.2 djay update.
You’re absolutely right. It wasn’t working as I was using an older edited midi preset. Changing it to default fixed it. Thank you ![]()
Perfect! Happy to hear that it’s working. Thanks for the follow up @Peter_Lazarenko
