Can I midi map djay pro stems with the Cdj nexus 2?
@Xamount it depends what OS you are using, but here’s a Neural Mix MIDI Mapping guide for macOS. You should be able to modify the built-in mapping as desired.
For more generic MIDI Mapping info, please refer to this guide:
