cdj2000nxs2
Got a setup with CDJ2000NXS2 and a DJM2000NXS cant get my DJ Pro to connect.
Same problem (CDJ-2000NXS2). I’m using DJayPro 1.4.3 and the “how-to connect” window for NSX2 pops up, but I follow the instructions and the software isn’t recognizing the midi/control inputs from the player.
Hey there,
thank you for your post.
Can you tell me which djay Pro version you are using?
Cheers.Lukas E.
