Will we still be able to use Djay Pro if there’s a cellular outage?
I’ve never had to use the “restore purchases” option previously with Djay Pro, and it’s got me concerned about reliability if and also when there’s cellular disruptions.
The app will still work if there is a cellular outage,
Obviously you won’t be able to stream music if you are using a streaming service and not using Wifi and not your own music.
And of course you wouldn’t be able to update to a new version of the app if you don’t have cellular or Wi-Fi service
Thanks for that @maurizio_T. You’re correct. Also, @tony_foo_yong some streaming services like Beatport and Beatsource LINK Pro offer offline lockers so they can be used without WiFi or cell service. You can always runs some tests, by putting your device in Airplane mode or disabling WiFi and Cellular data.
