After you select a Fx in the tap ( Window ), the tap close automatically! You must open the tap again to start the auto crossfade.
Please fix it and let it open until you start the autofade.
thanx!
Thanks for the suggestion. I have forwarded this to the dev team for consideration. In the meantime, please use the blue Vote button at the top left of this page so we can gauge user demand for this feature. Thanks!
@jessefunk, in the meantime, you might want to consider using the Mac keyboard shortcuts to perform the crossfader transition:
