CFX Tempo Blend issue
You’re welcome. Sounds good @Apos
I have figured it out.
It’s actually related to the crossfader curve switch on the controller. I know I replied to a previous post that it’s not working correctly but I does now! Seems the engineers found the way to implement it correctly, not sure since which release.
So, if the switch is in the off (rightmost) position, CFX doesn’t work as it should, as I demonstrated in the videos. If the switch is either in the middle or the leftmost position, it works fine!
Problem solved :slightly_smiling_face: and crossfader curve switch is working correctly now!
Thank you!
Excellent! Glad we got it sorted out @Apos. Thanks for the follow up and solution details!
