Can you make the EQ/NeuralMix selection button a toggle button instead of something that triggers a dropdown which only shows two options? It would save a tap/click. It feels clunky with the way it is currently implemented. (Aaaaaand… it looks having a one-click toggle is how the new Reloop MixTour Pro will work.)
If you’re using a controller you can assign the midi toggle to a button on the controller.
It’s the Toggle Neural Mix - EQ command you’ll need.
This does what you’re looking for.
I do this for when I am using my S4 but still would like it, especially for my iPad.
Thanks for the suggestion @kokernutz. I have forwarded this to the dev team for consideration.
