I use ddj400 iPad Pro and djay pro setup,
I don’t find how to change beat fraction(1/4, 1/2 1/8 etc) while using for instance echo fx, which seams to be an option on the contrôler.
Please help !
Please help !
Hi @Nyliaah,
You can change the Echo FX parameter and Dry and Wet setting by tapping FX in the djay tools.
Under the manual tab you can find the parameters of each echo deck.
I hope this is helping.
Another question, I just see one echo effect, can not find for instance low cut echo effect, is there a way to download or upgrade effects like this ?
Thanks a lot again
Hi thanks for answering ! This help a lot.
Envoyé de mon iPad
Envoyé de mon iPad
