Is there a way to change the new harmonic note back to showing what key it’s in instead?
The harmonic mixing “2B, 11A, 9B” ← (example) etc… is making it difficult for me.
Jennifer
Jennifer
I’m not sure how the menus are on MacOS, but on iOS go to Settings->Library->Format. Guessing it’s pretty similar.
Hey there. Thank you so much for your speedy response. I am assuming you’re talking about Settings in Apple Music?
I did that in Apple Music, but there wasn’t an to do that. This is what it looks like…
OK I figured it out. It was in DJ pro. Problem solved! Thank you, thank you thank you! Ever so grateful.
while you may not want to use it, numerical keys are very straightforward to use: two tracks should be compatible as long as they are at most one number or letter apart, ie 7A + 8A =
, 7A + 7B =
, 7A + 9A =
. Some people also say that you should consider also number and letter apart ie 7A + 8B =
which can be known as fuzzy keymixing. Whatever the case, always trust your ears. ![]()
