- Device model : iPad Air 5th Gen
- Version of operating system : iOS 26.5
- Version of djay : 5.6.5
- Hardware/controllers used : Inpulse T7
- Hardware firmware version
I recently bought Inpulse T7 and have been using it with Djay Pro on my iPad Air(5th Gen) – it works great, but I have one question. I’m connecting my iPad Air and the T7 via USB, and I have the T7 plugged into a power adapter with its power switch turned on. Is there any way to keep my iPad Air charging while it’s connected?
I tried using a USB-C hub/splitter with the iPad – I connected the T7 to one USB-C port on the hub and plugged a power adapter into another port to supply power to the iPad, but as soon as I do that, the T7 shuts off. Does anyone know how to charge the iPad Air while using the T7 at the same time?
Thanks in advance.
Hi @kangsta, you need a good quality, powered USB-C hub with pass through power delivery (PD).
- Connect it directly to your iPad’s USB-C connector.
- Then connect your Apple charger and cable to the PD/charging socket on the hub.
- Then connect your T7 to one of the USB-A or USB-C sockets on the hub.
- Make sure your T7 is also connected to power with its supplied adapter connected to a wall outlet.
- I recommend you choose a reputable hub brand like UGreen, Belkin, Anker or Baseus. I personally use the UGreen Revodok 1071.
So sorry for getting back to you so late, and thank you for the detailed explanation. I’ll go ahead and try it exactly as you suggested. Cheers!!!
No problem @kangsta. You’re welcome.
