Please introduce ‘Cue Points in Chronological Order’
As DJay currently is, the order that you set the cue point in the song, is the order that it stores the cue point to the pads regardless of where in the track it’s placed. This undesirable because if you first assign a cue point in the middle of the track and it gets stored to first cue pad, and you then set a cue point at beginning of the track, it then get assigned to second cue pad. This can get very confusing.
I just moved over from Serato DJ Pro for DJays fluid beat grid (absolutely genius btw) and it has the option to turn ‘Chronological Cue Points’ on and off and really miss that. Please make it so in DJay. Please!
