Hello, I plan to use Djay Pro on IOS with DVS support (Technics Turntables).
Does somebody know a good Souncard that is USB class compliant with IOS and has good phono preamp with a passthrou switch option to be able to use both analog vinyl with good quality and DVS ?
Thank you, I saw this soundcard also, the switch seems to be directly on the soundcard so it must.work but for the latencie issue this is a big problem.
I will perhaps need to change my mixer for a xone. Omnitronic mixers have also DVS output but I don’t now how it works, it should be nice if it’s split the turntable output so I can use a regular vinyl without the need of a soundcard.
I think I would try the Omnitronic mixers as the phono preamp are good and they have a DVS out to send the timecode signal. I can then choose a good quality USB C class Compliant interface with 2 stereo INs and 2 stereo OUts like audient offers.
Pioneer, A&H, Denon, Rane and Reloop all have mixers fully compatible with Algoriddim DJAY, including class compliant sound cards, fully midi mapped and DVS support.
I would say the best Analog preamps are either A&H or Rane’s
